How to build a mining rig
1. Let's choose the hardware
Look before you leap!
Motherboard
Nevertheless, we recommend choosing a newer motherboard for your peace of mind. No one can guarantee that old components will last another 16 years. Mental health and free time are worth more than a few dollars spent on new hardware.
🗿 The Processor (CPU)
If you are NOT going to mine using a processor, it’s performance doesn't matter.
If the processor is NOT involved in mining, running the OS and processes background processes will be the only task. So even an old Intel Core Duo E8400 is enough.
🔌Mining rig's power supplying
- Capacity. Calculate the total power consumption of all of your graphics cards and +200 watts of spare capacity.
- The number of connectors. Choose the PSU models with the most 6-pin and 8-pin connectors so you can connect all your graphics cards and raisers without any adapters.
- Certificate = Efficiency. Won't affect the quality of your PSU components, but it will save you money on your electric bill.
Connections and adapters
RAM
You assembled all the parts of the rig and are ready to go. Slow down and take a look at your rig. Have you connected everything correctly? For example, an improperly inserted RAM bar can prevent the farm from starting, but also reduce the hashrate on the CPU while mining.
Cooling Fans
Processor’s Cooler
☝ A cooling fan is good thing. An correctly installed cooling fan is even better!
Storage
Storage Types
- Speed. Using an SSD, your farm will startup fast, and you won't waste time waiting for your operating system to boot up.
- The lifespan of modern SSDs is high enough to handle the workload of a farm.
- Price no longer hits your wallet ~$30 for 250GB — with plenty of space to spare for the farm!
- It doesn't take up precious PCI-E lines.
Make sure that your motherboard and processor support enough PCI-E lines. NVME connector often combined combined with a PCI-E connector — you'll have to choose one or the other. A graphics card and the NVME storage may not work simultaneously.
Risers
Riser Types
The more GPUs — the better! But how to connect them if you don't have enough PCI-E x16 slots? Using a raiser, of course.
🩺Diagnostics
Motherboard’s self-diagnostic interface. If the motherboard is new, most likely it has complete or partial diagnostic tools. Color LEDs, or a numeric display to show the error code.
Motherboard with a POST Code Indicato
Speaker (aka Buzzer) Not to be confused with loud speakers! It must be plugged into a special motherboard socket.
Slightly outdated but still functional, BIOS diagnostic POST cards.
🎛 BIOS Setup
Usually, configuring the BIOS it's not difficult when your computer has a minimum of components. But when you connect several video cards, you start dancing with tambourines:
- In Task Manager, you don't see the card.
- The driver can't be installed.
- The card disappears and refuses to work at all.
- Update your motherboard’s BIOS — outdated BIOS may hide important BIOS settings.
- Enable Above 4G Decoding.
- Reduce the PCI-E speed to Gen2 or Gen1.
- Disable the integrated GPU if the system is unstable or there are not enough PCI-E lanes.
- Turn on the Resizable Bar (Dynamic Bar) option, if available.
- Disable CSM mode.
- Unload the first SATA ports on your motherboard. Connect an SSD or hard disk drive with SATA 4,5,6 connectors...
Paging file
We will tell you how to do it and how much to set it.
Power settings
On the selected power profile, click "Power Scheme Settings” Next, click on "Change Advanced Settings”
Find "Hard Disk" → "Turn off hard disk after" → set to "0" — “Never”
Prohibit USB Ports suspension
3. Install Kryptex!
C:\Users\<username>AppData\Local\Programs\kryptex-app
C:\Users\<username>AppData\Roaming\Kryptex
4. Helpful hints
- If you have Nvidia and AMD video cards installed in the same rig simultaneously, follow the order of drivers installation. Firstly, install the Nvidia, then the AMD. If it is vice versa - AMD cards may not be detected!
- Don't rush to install the latest drivers! Drivers should be up to date, but not necessarily the latest. So make sure the driver version you are going to install is stable! Taking lessons from mistakes https://www.kryptex.com/en/news/nvidia-496-en
Are you using Nvidia drivers? Turn on "Maximum Performance" in the 3D settings in the Nvidia control panel.
You have GTX 1080, 1080Ti, Titan XP graphics card? ETHlargementPill can boost your hashrate!
Hashrate drops, and the Pills with arguments don't help? Make sure the miner is running with the administrator rights!
AMD RX 400/500 series cards? Enable compute mode.
- Don't overclock the cards much as possible. Watch the stability of the mining rig for at least 24 hours, only then step by step overclock your video cards.
- Use wired Internet. It will increase stability, speed up access to the pools, protect against radio interference, and increase your income!
- Mining rig with a Steel frame? Ground the farm! A large amount of electronic components generate static and electromagnetic fields. The powerful appliance needs to be grounded!
- Use a wattmeter or a smart plug. Monitor the consumption and control power remotely.
- More useful tips for stable mining
Just kidding! 😅
If you don't want to or can't mine on Window with our super handy software for some reason, we've given you the option to mine the way you like!
- How to connect to Kryptex pools directly (using the email)
- How to connect HiveOS to Kryptex (universal way)
- How to connect HiveOS to XMR pools of Kryptex
- How to connect RaveOS to Kryptex (universal way)
Any questions left?
