Cześć!👋🏻 Jak możemy pomóc?
25 października 2021 14:47
  • in Ethereum ETH;
  • in Litecoin LTC;
  • in USDT (BEP20, TRC20);
  • in USDC (Solana);
  • BNB (Smart Chain);
  • Volet.com payouts;
  • Bitrefill payouts.
Available connection options:
  • krxXXXXXX
  • krxXXXXXX/Worker1
  • krxXXXXXX.Worker
  • krxxxxxxx.Worker
  • KRXXXXXXX.Worker
  • [email protected]/worker
How to connect?
Alternatively, you can use your email as the wallet address. However, not all miners support this format. If you choose to use your email, include the worker name by adding a slash. Example: [email protected]/worker.
BTC+FB btc.kryptex.network:7777 mining_username.worker_name x or nothing
FB fb.kryptex.network:7777 mining_username.worker_name x or nothing
XEC xec.kryptex.network:7777 mining_username.worker_name x or nothing
DGB dgb.kryptex.network:7777 mining_username.worker_name x or nothing
BCH bch.kryptex.network:7777 mining_username.worker_name x or nothing
LTC+DOGE+BEL+PEP ltc.kryptex.network:7777 mining_username.worker_name x or nothing
ALPH alph.kryptex.network:7777 mining_username.worker_name x or nothing
KAS kas.kryptex.network:7777 mining_username.worker_name x or nothing
RXD rxd.kryptex.network:7777 mining_username.worker_name x or nothing
ETC etc.kryptex.network:7777 mining_username.worker_name x or nothing
ETHW ethw.kryptex.network:7777 mining_username.worker_name x or nothing
OCTA octa.kryptex.network:7777 mining_username.worker_name x or nothing
XMR xmr.kryptex.network:7777 mining_username.worker_name x or nothing
SAL sal.kryptex.network:7777 mining_username.worker_name x or nothing
ZEPH zeph.kryptex.network:7777 mining_username.worker_name x or nothing
CFX cfx.kryptex.network:7777 mining_username.worker_name x or nothing
XEL xel.kryptex.network:7777 mining_username.worker_name x or nothing
IRON FISH iron.kryptex.network:7777 mining_username.worker_name x or nothing
KLS kls.kryptex.network:7777 mining_username.worker_name x or nothing
RVN rvn.kryptex.network:7777 mining_username.worker_name x or nothing
CLORE clore.kryptex.network:7777 mining_username.worker_name x or nothing
XNA xna.kryptex.network:7777 mining_username.worker_name x or nothing
ERGO erg.kryptex.network:7777 mining_username.worker_name x or nothing
NEXA nexa.kryptex.network:7777 mining_username.worker_name x or nothing
Connect on Windows
Connect on HiveOS
Creating the Wallet
  4. Confirm the wallet setup.
Create the Flight Sheet
Connect on RaveOS
Creating the Wallet
Connection Settings
  1. Choose the coin type.
  7. Save your configs.
  3. Next, follow these steps:
    • Select the appropriate wallet for from the “Wallet” drop-down list.
Connect on ASIC/FPGA
❗Important Information
  3. Not all coins can be mined and exchanged for bitcoins. Check the table to see which coins available for automatic exchange.
🚑 Need Help?
Zarejestruj
